1.54" Monochrome eInk ePaper SPI 152x152 Display
A 1.54-inch monochrome e-paper breakout with SPI and an onboard 8KB frame-buffer SRAM.
0 followers
A 1.54-inch monochrome e-paper breakout with SPI and an onboard 8KB frame-buffer SRAM. Key specifications: - 152×152 pixels - SPI display and SRAM - 8KB SRAM - 3.3V or 5V input - Regulator enable pin
A label or status display often spends more time holding an image than changing it. This 1.54-inch e-paper panel keeps its black-and-white image without continuous display power, making a different tradeoff from a continuously updating screen.
An 8KB SRAM chip shares the SPI interface and holds image data outside the host MCU. That helps a small controller such as an ATmega328 work with the 152 × 152-pixel panel without dedicating all its own memory to a frame buffer.
Full refresh takes a couple of seconds, so this suits occasional updates rather than animation. The board accepts 3.3V or 5V and has a regulator-enable pin to power down the display and SRAM.
Key specifications:
• 152×152 pixels
• SPI display and SRAM
• 8KB SRAM
• 3.3V or 5V input
• Regulator enable pin
Product documentation: https://www.questwiseventures.com/products/1-54-monochrome-eink-epaper-spi-152x152-display
Possible uses include a desktop status display, an inventory label, a price label or a short task list. A controller could update the information when something changes, then leave it visible until the next update. These are possible applications, not completed builds.
  • Ideas for information that stays on display
    Michael Yim • 10/16/2026 at 06:04 • 0 comments
    A small ePaper display could be useful for information that stays visible for a while and only needs an occasional update. Some possibilities are a desktop gadget, a status display, an inventory or price label, or a simple list.
    These are possible uses for the panel, rather than projects I have built with it. I would start with a small amount of information that someone wants to keep in view, without needing a continuously changing screen.
View project log
