The hardware design is complete. I have a monitor program running and my own version of FORTH.
I designed two other versions of the CPU board. The second version is for a 6800 CPU. The third version is for either a 6502 or 65C816 CPU based on which of set of configuration pads are soldered. These two other CPU board versions can be used with the front panel board.
I am very busy with work. I will add more information about this project as my time permits.
Please note:
While this project and the Membership cards created by Lee Hart may have some passing similarities Lee Hart was not involved in any way with the design or programming of this project.
Kevin
