- One OS, many boards
The ESP32 family (ESP32, S2, S3, C3, C6, with or without LoRa) and the ESP8266, from the same sources. On the ESP32 family the same code builds with Arduino and with ESP-IDF.
- Two editions
The normal edition for the ESP32 family, a light edition for the boards with little memory. A module asks the system for its own values on a board without touching the OS. - A console in the device
A web app served by the board itself, made for the phone first, in English and Italian. No cloud and no app to install: open the address of the device. - Modules that only say what they are
A module declares its state, its settings and its commands. The system carries them to the console, to HTTP, to MQTT and to the serial port, and draws a standard page for them. A module can bring a page of its own in one file. - Ready for the house
Devices announce themselves on the network and find each other. With an MQTT broker they show up in Home Assistant by themselves: switches, lights, sensors and buttons, and what can be set, a number, a choice, a text. From there, automations, dashboards and the voice assistants. - Native data, JSON at the borders
Inside the engine the data are C++ structures in fixed memory; JSON exists only where the device talks to the outside. - Developed on the PC
The whole system runs on the PC as a simulator with its console in the browser, and more than 500 tests run there without a board. - Open to a server of yours
A cloud service waits for a bridge: a module can connect the device to any server, with one envelope for the data. Without one the device works fully on its own.
SeventyFive
mircemk
Bikash Narayan Panda
Andrew Byrley
Timm Bogner
