This assembly combines a 40kg-rated load cell, an already-connected HX711 board and an acrylic weighing platform. You can connect it to your own controller and write a program around the readings.
Possible uses include weighing packages, monitoring changes in a storage bin’s weight, or detecting when an object is added or removed. Your program could display the weight, log changes or flag a threshold. These are ideas for users to build on, not applications I have already implemented.
I have not calibrated the assembly. Users should zero and calibrate their own setup with known weights before relying on its readings.
Michael Yim
Peter McCloud
electronicsworkshops
8bitflynn
Alexander Dvorkovyy
