FIRE Withdrawal Math That Survives Bad Decades
A withdrawal simulator project: sequence-of-returns risk, 4 percent rule failure points, and survival checks that catch bad decades.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A retirement spreadsheet I trusted failed its first honest test. The 4 percent rule looked safe on average returns, but running real year-by-year histories showed a flat decade right after quitting breaks the plan even when the long-run average recovers. Sequence of returns dominates the first five years of retirement. The fix was a survival check pass: replay the plan against a flat decade up front, then price each spending rule by what it saves in down years. Trimming discretionary spending 10 percent after losses bought more survival than any allocation tweak I tried. The expected-value habit carried over to spending, since a pricey course has to beat index returns for decades to justify itself. Simulator notes and the withdrawal math: https://firenomics.com/
