What the heck?
The ImageWriter II is a great printer, but it has no network port. Printing to one usually means keeping an old Mac around, or a modern computer with an old Ghostscript driver. I wanted to print to mine straight from my phone, so I made a dongle that does all the work itself.
It's an ESP32-S3 on a custom board with two mini-DIN ports, one for the printer and one for LocalTalk. When you hit Print, AirWriter takes the job over Wi-Fi, dithers it with Atkinson dithering (the same one the original Mac used), converts it to the ImageWriter's graphics mode and sends it down the serial cable. It uses the same Apple cable that connects the printer to a Mac, so you probably already have one.
If the printer runs out of paper or someone presses SELECT, your phone gets an alert, and the page carries on once you fix it.
The PCB design
The top case is a second PCB with no parts on it, just artwork. Its grid of dots is made from bare FR4, soldermask and gold, and 37 RGB LEDs behind it show what the printer is up to. A little print head runs across the dots while it prints, they turn amber when it needs paper, and they glow like embers when the printer is switched off.
I ordered the PCBs from PCBway, using the "ENIG Gold" process with black matte solder mask. The ENIG process uses a thin layer of real gold on the bare copper contacts that won't tarnish, and the board finish is overall much smoother than you can get from HASL.
Overall I'm really happy with the quality. It was a bit of a risk because I've never done ENIG before, and it's more expensive. Because the PCB is part of the product design itself, the fit-and-finish needs to be pretty high.
Delivery took longer than usual, but I'm really happy with how the boards look and PCBway's customer service was helpful throughout the process. In my next batch I'm going to try transparent PCBs since the yellowish FR4 seems to block almost all of the blue and violet light shining through from the RGB LEDs below.
Project status
It all works end to end now. My iPhone and MacBook print over AirPrint, and my SE/30 prints with the regular ImageWriter driver in System 7.5.3, over a LocalTalk cable or over Wi-Fi through its BlueSCSI. As far as the Mac knows, it's talking to Apple's LocalTalk card! Basilisk II and Infinite Mac can print to it too, and with Apple's color ribbon in it prints in color. Home Assistant's printer integration even picks it up.
Settings live on a little web page that looks like a Platinum settings app, and firmware updates come straight from GitHub releases.
I've only tested it on my ImageWriter II. The original ImageWriter and the ImageWriter LQ take the same commands, so they should work, and I'd love to hear from anyone who can try one. I'm working on LaserWriter support next.
The LocalTalk side runs on TashTalk by lampmerchant (Tashtari), and its wiring comes straight from FeralFirmware's TashTalkUSB. polpo's ImageScribbler is what I leaned on for the AppleTalk part, and Infinite Mac is Mihai Parparita's. Thank you all!
Wells Workshop
johnowhitaker
Hulk
the.wretch
