I started designing this device after hearing Samy Kamkar's DEF CON talk about laser mics. He mentioned that the TrueDepth LiDAR on the back of iPhone Pros could be detected. I built a device which does exactly that, but after discovering how many different potential-nuisance devices emit a signal which could be detected the same way I redesigned the device to widen the range of bands and frequencies it can detect, like ALPRs!
I've designed the form factor to work as a standalone USB-powered device which could be clipped onto a car visor or worn as a conference badge, as well as plugged into a Flipper Zero with an accompanying app!
The current prototypes are designed on SAMD21 and ESP32 platforms, with the latter including the exciting capability of connecting to a phone over bluetooth, or Home Assistant over Wi-Fi.
During the early stages of this concept I wrote two blog posts for my employer on the hardware and firmware designs, you can find links to these in the external li
After long last! After half a dozen re-designs! After a couple dozen sensor concept tests on bread boards!
Now that the sensors design is settled and prototypes are in hand, I am working on locking down presets for different ALPR cameras (Flock, Axon, blah blah blah) and deciding whether this should be on an ESP32 with a phone app, or if I should keep it on the SAMD21 and super cheap. Swapping between these platforms became enough of a back and forth during design that I still have the ugly ifdefs to try to compile for both. I think the device will be more accessible and useful through a phone than any kind of PCB UI. That is a little while later problem though, first I need to make more presets.
And with this I have also given it a cuter code name: IRish Setter. Get it? Because its pointing out the Flock?
Anyway, I have prototype boards in hand and I'm off point circuit boards at ALPRs and write stuff down until the cops show up! Wish me luck!
