Why Quiesco
Environmental monitors have boomed: Aranet, Airvalent and friends made CO₂ tracking friendly. But they are general-purpose. They watch the air, and little else, against office standards.
Quiesco is built for the bedroom. Light and noise matter as much as CO₂ and temperature for a good night, so it measures all of them and judges each one against a comfort band. Every reading is actionable:
| When it says… | …you can |
| CO₂ is high | open a window or run ventilation |
| too warm, too cold | adjust heating, cooling or bedding |
| too dry, too damp | humidify or dehumidify |
| too much light | close the blinds or wear a sleep mask |
| too loud | check the insulation or reach for earplugs |
And unlike commercial devices, it is completely open and unlocked: it runs the Arduino bootloader, so you can change the firmware with the Arduino IDE or your favourite editor.
What it measures
| Reading | Sensor | Comfortable | Warn | Bad |
| CO₂ | Sensirion SCD41 (photoacoustic NDIR) | ≤ 800 ppm | 800–1000 ppm | > 1000 ppm |
| Temperature | Bosch BME280 | 16–20 °C | 14–16 · 20–24 °C | < 14 · > 24 °C |
| Humidity | Bosch BME280 | 40–60 % | 30–40 · 60–70 % | < 30 · > 70 % |
| Noise | Knowles SPH0641LU4H-1 PDM mic, dB(A) Leq over ~7 s | ≤ 45 dB | 45–55 dB | > 55 dB |
| Light | Vishay VEML7700 | informational | ||
| Pressure | Bosch BME280 | informational; also compensates CO₂ |
The same bands drive the e-ink screen and the app, so the phone and the panel always agree.
How it works
Every interval (1, 5, 10 or 30 minutes; default 5 minutes) the unit powers up its sensor rail, measures everything, applies your calibration offsets, appends the reading to its on-board log, redraws the e-ink panel only if the picture changed, then powers the rail down and sleeps. A sensor that fails is reported as unavailable, and the cycle carries on without it.
The app enrols with a unit while it is on USB power, using a six-digit code shown on the panel. After that it sets the clock, downloads the log, charts each night and lets you pick the screen or calibrate the sensors. One phone can hold several units, each with its own name and sleep window.
Specs
| MCU | Nordic nRF52840 on a Seeed XIAO nRF52840 Plus module, Arduino bootloader |
| Connectivity | Bluetooth Low Energy; only an enrolled phone can read data or change settings |
| Sensors | CO₂, temperature, humidity, pressure, light, noise |
| Display | GoodDisplay GDEW0154T8D, 1.54″ 152 × 152 e-ink, holds its image unpowered |
| Storage | Winbond W25Q64 8 MB SPI NOR flash (config + sample log) |
| Power | 3.7 V ~400 mAh LiPo, USB-C charging, switched peripheral rail |
| Expansion | JST I²C and UART headers |
| Case | 3D-printable two-part enclosure, four M3 screws |
Everything (PCB, case, firmware and app) is in the repository: github.com/OxMarco/Quiesco
Marco
Viacheslav
sadwizard
x-labz
Osman Mazinov
