EFNMR Quantum Computer Project (NMRQCP)
Democratizing Quantum Computing "If it doesn't exist, we build it. Quantum Computer on your desk."
An open-source Earth's Field NMR (EFNMR) Quantum Computer built from scratch.
   I'm a 15-year-old KOSEN (National Institute of Technology in Japan) student building a DIY Earth's Field NMR Quantum Computer (EFNMRQC). My team and I are tackling everything from analog circuit design to FPGA control and signal processing through endless trial and error. In these project logs, I'll be sharing our technical discoveries, hardware struggles, and everything we learn along the way!
  • 1 × M5Stack CoreS3 Lite (ESP32S3) System control unit
  • 1 × M5Stack Mini Relay Unit Pulse control
  • 1 × StarTech.com 96KHz/24-bit Hi-Fi USB Sound Card Signal digitization / PC data acquisition
  • 1 × BNC to 3.5mm Mono Plug Adapter Connection to the sound card
  • 2 × Analog Devices AD797BRZ Ultra-Low Noise Op-Amp Small signal amplification (SMD)
View all 25 components
  • Outdoor Testing: Noise Dropped, but the FID Disappeared! (Troubleshooting the Q-Dump Circuit)
    S.I. • 10/28/2026 at 10:37 • 0 comments
    Hi everyone! I’m a KOSEN student building a DIY EFNMR Quantum Computer.
    In this log, I want to share the results of our recent outdoor measurement tests, where we tried out a new circuit designed to counter our dead-time issues.
    Outdoor Measurement Result
    We Couldn't Catch the FID Signal This Time...
    As you can see in the photo above, the overall noise level definitely dropped, but the peak around 2000Hz completely disappeared. During our last test, we clearly saw a sharp, cone-shaped peak right around 2000Hz emerging from the noise.
    The Previous Success Was a Miracle
    After reviewing the data (and discussing it with my AI assistant), we concluded that while the signal we caught last time was absolutely real, it was a miraculous alignment of signal strength, noise, and dead-time conditions. The FFT just barely managed to catch the "tail end" (the tiny, final decaying part) of the damped sine wave.
    A Fatal Flaw in the Q-Dump Circuit
    To combat the dead time, we had integrated a "Q-dump circuit" into the amplifier. However, I made a critical mistake in its design. I was supposed to include a resistor to dissipate the massive unwanted surge energy as heat, but I completely forgot to add it!
    Because of this missing resistor, it's highly likely that the unwanted surge signal was just looping back into the amplifier circuit. This flaw probably made it even harder for our "miracle" peak to show up this time.
    Noise Dropped, but Dead Time Remains
    Noise Drastically Reduced!
    By moving our testing setup outdoors, we were able to drastically reduce environmental noise! We will definitely be using this outdoor location for all future measurements. This alone is a huge step forward!
    The Lingering Dead Time Problem
    Even though we implemented countermeasures, you can still clearly see the massive dead-time disturbance in the graph. This is almost certainly due to my mistake with the Q-dump circuit.
    For our next test, I will fix the Q-dump circuit by adding the proper resistor. I will also consult with our team members to adjust the software side (microcontroller timing, etc.), which we couldn't do this time due to scheduling conflicts!
    The 500Hz Peaks? That's Relay Bouncing!
    In the FFT section of the graph, you might notice a repeating signal forming gentle peaks every 500Hz. This is actually caused by contact bounce (chattering) from our M5 Relay! When the mechanical relay switches, the internal metal plates bounce against each other microscopically. That rapid bouncing creates the square pulses you see in the top time-domain graph.
    I won't fix this immediately, but if we determine that it's severely affecting our measurements later on, we might implement a software countermeasure—like deliberately ignoring all data for the first few milliseconds right after switching.
    Personal Note: Embracing the Struggle
    It is incredibly frustrating and sad that we couldn't measure the FID signal this time. But honestly, trouble is par for the course in hardware development. I'm sure the engineers building state-of-the-art quantum computers on the front lines deal with this exact same frustration every day. Accepting that this is just part of the process, I am going to keep pushing this project forward with everything I have!
    Follow Our Journey!
  • Member of Project
    S.I. • 10/19/2026 at 12:09 • 0 comments
    Up until now, I’ve mostly talked about the hardware and code, but in this log, I want to share how this project evolved from a solo endeavor into a real team effort, and introduce our current member roles!
    How the Team Was Formed
    From Idea to Project Launch
    As I mentioned in earlier logs, this project started when I researched whether I could build my own quantum computer and discovered the Earth's Field NMR (EFNMR) method, which could be built for around 100,000 JPY (approx. $700).
    Once I knew it was possible, I obsessively researched the topic, used AI as a sounding board, and started by simulating signal generation and FFT in Python. While drafting the FPGA architecture and overall system design, I managed to secure the funding, quickly finalized the parts list, and ordered everything at once. That’s when this project truly kicked into high gear.
    Recruiting Members: The First Two Join
    My parents advised me that it’s always better to have teammates when tackling a big research or engineering project. Plus, knowing I had to hand-wind hundreds of meters of wire for the coil, I realized I absolutely needed backup. So, I made a pitch video explaining the project overview and started recruiting at my school.
    Two of my friends stepped up and said they wanted to join! At that stage, I was still acting as the central hub driving all the technical fields, and they assisted me with the physical builds and testing all the way up to our first successful FID signal observation.
    Expanding the Crew: Two More Join
    As the project advanced, I realized that trying to solo-lead every single technical domain was exhausting, and it didn't feel like a true "team" yet. I decided we needed to divide and conquer. Realizing that three people weren't enough for the scale of this project, I opened recruitment for three more members (two for technical roles, one for PR/Design).
    A few days later, two more technical members officially joined! (Unfortunately, we couldn't find anyone for the PR/Design role...)
    Team Roles & Division of Labor
    1. C++ (Microcontroller Control)
    This member handles the M5Stack programming and system control. In the future, we plan to shift the signal processing to an FPGA and the microcontroller, transmitting the data wirelessly to a smartphone or PC for better usability. This role will be crucial when we build that standalone wireless system.
    2. Python (Signal Processing)
    This role focuses on PC-side signal processing, like our real-time FFT analyzer. As I mentioned above, once we transition to our final standalone hardware architecture and phase out the PC, this member will likely shift over to help with the heavy C++ workload.
    3. CAD (Schematics & Hardware Design)
    This member is responsible for drawing up our circuit schematics. Eventually, they will create full 3D CAD models of the hardware assembly and design custom PCBs to help us reduce analog noise.
    4. Electronic Circuits (Hardware Tuning)
    This member focuses on understanding the deep mechanics of our analog circuits. Their job is to make on-the-fly adjustments during experiments—like instantly tweaking the op-amp gain—and to identify exactly which part of the circuit is picking up environmental noise.
    5. Quantum Theory, FPGA, Project Lead, and Writer (Me)
    • Theory: I study quantum mechanics and quantum computing from first principles to guide the overall architecture and instruct the team based on the physics we need to achieve.
    • FPGA: I am writing the HDL to build the final processing system. (I decided to take this on myself because mastering FPGA development is an essential skill for my dream of becoming a professional quantum hardware engineer!)
    • Project Lead: I brainstorm our next moves with the team, make the final decisions, and manage the project's overall roadmap.
    • Writer: I write the project logs for Zenn, GitHub, Hackaday, and post updates on X. I...
  • Project Schedule & Roadmap
    S.I. • 10/17/2026 at 11:41 • 0 comments
    In this log, just as the title says, I want to share our future roadmap and development schedule for the project.
    2026
    • Until Nov: Tackle dead-time issues and begin hardware noise countermeasures (adding HPF, etc.).
    • Nov: Project paused for school exams.
    • Nov 10 – Nov 30: Preliminary judging phase for "Heroes League" (a major tech contest in Japan).
    • Early to Mid-Dec: Solder the amplifier circuit to a perfboard and implement coaxial cable shielding for noise reduction.
    • Late Dec: Search for optimal measurement locations (outdoors) and capture a perfectly clean FID signal.
    • Dec 5: "Heroes League" Online Finals (if we pass the preliminaries!).
    • Dec 19: "Heroes League" Award Ceremony (if we make it to the end!).
    • Year-End / New Year: Project paused for winter break.
    2027
    • Early Jan: Buffer/Contingency period for hardware delays.
    • Mid-Jan to Early Feb: Project paused for school exams.
    • Mid-Feb: Migrate processing to FPGA and implement Noise Countermeasures Phase 2.
    • Mar: Spring Break! Focus on simulating quantum spin manipulation and building a noise-canceling system.
    • Apr: Conduct actual spin manipulation experiments.
    • May: Accumulate and analyze data from spin manipulation.
    • Mid-May to Early Jun: Project paused for school exams.
    • Jun: Completion of the 1-qubit EFNMR Quantum Computer!
    • Jul: Project paused for school exams.
    • Mid-Aug to Early Sep: Summer Break (Compiling all results, writing documentation, and publishing the final reports).
    I will update the schedule beyond this point once we reach those milestones.
    Personal Note
    While writing out this schedule, I realized just how much development time I lose to school exams and dorm closures during long breaks. Being a student maker has its scheduling challenges! I really need to increase my weekly work pace during the weeks when I do have time to build.
    Follow Our Journey!
  • I Saw a Real Superconducting Quantum Computer Chip
    S.I. • 10/17/2026 at 07:10 • 0 comments
    In this log, I want to take a quick break from our DIY hardware to share a personal story about the time I visited the National Museum of Emerging Science and Innovation (Miraikan) in Tokyo to see a real superconducting quantum computer chip on display.
    My Trip to the Miraikan
    "Under Maintenance!?"
    Right after graduating from middle school, during my spring break, I had some free time. I had been wanting to see a real quantum computer chip for a long time, so I went to the Miraikan. The moment I arrived, I made a beeline for the quantum computer exhibit. However, right where the chip was supposed to be displayed, there was a sign that said, "Under Maintenance." I was honestly a bit heartbroken.
    Despite that, the rest of the exhibits at the Miraikan were incredibly fascinating. Even without seeing the quantum chip, I ended up staying there all day, from opening until closing time! The highlight of that trip was the dome theater showing a movie called "The Man from the 9 Dimensions," which was an amazing visual exploration of Superstring Theory.
    Finally Seeing the Chip!
    Fast forward to this summer break: I went back to the Miraikan for my revenge (?). Just like last time, I headed straight for the quantum exhibit. And this time... the chip was actually there!
    I was incredibly excited to finally see the superconducting quantum chip I had been dreaming about. My first impression upon seeing the real thing? It was much smaller than I expected! I had always imagined it would be around 5cm square, but it was actually only about 3cm square.
    By the way, I watched "The Man from the 9 Dimensions" again on this trip! I went on a weekday afternoon in September, and it was surprisingly crowded (maybe because the museum is about to close for a 6-month renovation?). Seeing the real hardware up close gave me a huge boost of motivation to keep working on my own DIY quantum computer on my desk!
    Follow Our Journey!
  • Noise Reduction Strategies
    S.I. • 10/17/2026 at 07:06 • 0 comments
    In this log, I want to share the 7 hardware upgrades and noise reduction strategies we are planning to implement next in order to clean up our FID signal.
    1. Sealing the Aluminum Shielding Enclosure
    Currently, because we have cables running in and out of the aluminum case, we can't close the lid completely. Environmental noise is leaking through this gap. The best solution is to drill small, exact-sized holes in the enclosure for the cables to pass through. Drilling is a bit of a last resort because it's difficult, but it's the most effective way. Another option is sealing the gap with aluminum tape, but peeling it off every time we need to tweak the circuit would be a nightmare.
    2. Migrating the Amp from Breadboard to Perfboard
    Right now, our ultra-low noise amplifier circuit is built on a breadboard. However, the breadboard itself acts as a giant antenna, picking up noise and feeding it straight into the op-amp. To fix this, we will permanently solder the amp circuit onto a universal PCB (perfboard).
    3. Adding an Analog High-Pass Filter (HPF)
    We plan to physically filter out low-frequency environmental noise before it even reaches the ADC. We will build an analog High-Pass Filter (HPF) using film capacitors and resistors directly into the amplifier circuit.
    4. Coaxial Shielding for the Coil-to-Amp Connection
    We are currently using standard jumper wires to transmit the microscopic signal from the sensor coil to the amplifier. We will replace these jumpers with shielded coaxial cables to block electromagnetic interference (EMI) during signal transmission.
    5. Twisting the Polarization Battery Cables
    The thick cables running from the 12V lead-acid battery to the polarizing coil are currently just bundled together. When a massive current flows, they generate their own magnetic field, causing internal noise. We will twist the positive and negative cables together (creating a twisted pair) to cancel out the emitted magnetic fields.
    6. Adding a Relay to the Polarization Circuit
    Currently, the high-current polarization circuit is controlled solely by a MOSFET. By integrating a mechanical relay into the circuit, we will be able to physically isolate and disconnect the polarization circuit from the amplifier during the highly sensitive receiving phase.
    7. Changing the Measurement Location (Going Outdoors!)
    For our recent successful FID observation, we measured in a room with relatively stable magnetic fields. However, a room is still inside a building—surrounded by rebar concrete and electronic devices emitting noise. To eliminate these sources entirely, we plan to pack up the system and run the experiment outdoors in a wide-open park!
    Personal Note: The Real Fun Begins!
    Now that we’ve entered the noise-reduction phase, this project feels more like real quantum computing than ever! Noise is one of the biggest hurdles in cutting-edge quantum computer development right now. This is where the real struggle—and the real fun—lies. To achieve my dream of becoming a quantum hardware developer, I am going to grind through these noise countermeasures and level up my engineering skills!
    Follow Our Journey!
  • Our Concept and Our Catchphrase.
    S.I. • 10/17/2026 at 07:03 • 0 comments
    In this log, I want to share the origin of our project name, the meaning behind our logo, our core concept, and our newly created catchphrase.
    Origin of the Project Name
    NMRQCP
    This is both my profile name and the official name of our DIY quantum computer project. NMRQCP comes from the initials of "Earth's Field Nuclear Magnetic Resonance Quantum Computer" (EFNMRQC). Since EFNMRQC was a bit too long, we dropped the "EF" to make it NMRQC, and added a "P" for Project—resulting in NMRQCP.
    What Our Logo Represents
    NMRQCP Logo
    This is the official logo of our project. The Bloch sphere in the background represents quantum computing and the manipulation of quantum states, while the waveform in the foreground represents the actual NMR signal (FID wave) that we capture and read with our EFNMRQC hardware.
    Project Concept
    This is the core concept driving our project. Right now, actual quantum computer hardware is locked behind closed doors—accessible only to massive corporations, research institutes, and universities. Our mission is to change that and make quantum hardware accessible to anyone.
    By developing a low-cost, easy-to-build quantum computer and open-sourcing all of the designs and code online, I want to help build a society where anyone can get hands-on experience with quantum hardware—a truly democratized quantum future.
    (If you want to read more about why I want to make this accessible to everyone and how I first got into quantum mechanics, check out our project details or this article (in Japanese).)
    Our Catchphrase
    "If it doesn't exist, we build it. Quantum Computers on your desk."
    The first half—"If it doesn't exist, we build it"—comes from my lifelong maker motto. I desperately wanted to touch and tinker with quantum computer hardware, but had zero access to it. This project was born out of that exact frustration: if there's no way for me to touch one, I'll just build one myself.
    The second half—"Quantum Computers on your desk"—captures the exact defining feature of this project: creating a quantum computer compact and accessible enough that anyone can build and run it right on their own desktop.
    Follow Our Journey!
  • Observing the FID Signal!
    S.I. • 10/17/2026 at 07:01 • 0 comments
    In this latest experiment, we finally succeeded in capturing the FID signal (damped sine wave)!
    Observed FID Signal and FFT Peak
    First, the FID signal of hydrogen atoms (protons) in the Earth's magnetic field occurs at a frequency right around 2000Hz to 2100Hz.
    If you look at the bottom graph in the photo, right around the purple dot between 2000Hz and 2100Hz, there is a distinct, sharp peak. This is the exact FID signal we’ve been hunting for!
    However, looking at the top time-domain graph, you can't really see a clear damped sine wave. We believe this is because a massive dead time is occurring in the green section due to residual surge current from the coil switching.
    This also explains why the peak around 2000Hz–2100Hz is relatively small. Because of the dead time, we are losing the initial head of the damped sine wave where the signal amplitude is at its strongest. What the FFT graph is actually showing is the tail end of the microscopic FID signal—those tiny oscillations right after the green dead-time line drops back to zero in the top graph.
    Future Challenges & Countermeasures
    This experiment brought two critical hardware challenges to light:
    • Due to dead time, we are missing the most crucial data right after sequence switching.
    • The signal is still nearly buried in analog noise.
    Personal Thoughts: A 6-Month Journey & The 0.25x Speed Discovery!
    I am beyond thrilled that we finally observed the FID signal! It took us about half a year to get to this point. For six months, spending hours every single day researching, brainstorming, building, and testing has finally paid off!
    This experiment was the very first time we ran all the circuits together and performed real data analysis. Funny enough, while we were running the experiment, I didn't even realize the FID signal had appeared. Because the signal flashes by in a fraction of a second, we were recording a video of the screen and playing it back at 0.5x speed—and we couldn't find anything. I thought we had failed.
    However, a little while after returning to my dorm room, I uploaded the video to Google Photos and rewatched it at 0.25x speed. Suddenly, I thought, "Wait... could this be it?!" I paused the video and scrubbed through it frame-by-frame manually—and there it was: the exact frame showing the FID peak on the graph! Going from the disappointment of thinking it failed to discovering we actually caught it made me unbelievably excited.
    Riding this momentum, we are going to keep tackling the dead-time and noise issues head-on and complete this DIY quantum computer!
    Follow Our Journey!
  • [Archive] Project History & Early Development (Apr - Sep 2026)
    S.I. • 10/17/2026 at 06:59 • 0 comments
    💡 Archived Development Logs: This post compiles the early records of our project (Chapters 01–14). Since I didn't have time to write massive foundational articles while building the hardware in parallel, I used AI to help structure the text for these early logs. (Starting from our latest log where we successfully observed the FID signal, everything is written 100% in my own words!)
    01. What is a Quantum Computer?
    First, the computers inside our smartphones and PCs are called "classical computers."
    Classical vs Quantum Computer
    Differences from Classical Computers
    Simply put, quantum computers are orders of magnitude faster at specific calculations. For example, Google reported that their quantum computer (Willow) solved a calculation in 300 seconds that would take a supercomputer longer than the age of the universe (about 13.8 billion years). That makes it roughly 1.5 quadrillion times faster. However, quantum computers have strengths and weaknesses—they aren't faster at everything, and classical computers still beat them in many everyday tasks.
    What Can They Do? (Present & Future)
    Quantum computers excel at simulations and optimization, analyzing far more patterns than classical machines.
    Current Applications
    • Current Applications: Optimizing delivery routes and factory production lines (Japan Post, Denso), financial simulations (MUFG), exploring stable chemical structures for drug discovery (PeptiDream, Fujitsu), and elucidating chemical reaction mechanisms (Mitsubishi Chemical).
    Future Applications
    • Future Potential: Next-gen material discovery (more efficient solar panels, CO2 capture), molecular-level drug simulations with zero side effects, hyper-accurate weather forecasting, infrastructure optimization (solving traffic jams), artificial photosynthesis, breaking current cryptography (driving the shift to post-quantum cryptography), and advancing fundamental physics (I personally hope quantum simulations bring us one step closer to the "Theory of Everything").
    Timeline & What Students Should Do
    As of 2026, quantum computers are entering the practical phase, though still far from perfect. Near-complete machines are expected around 2030, and fault-tolerant general-purpose quantum computers around 2050. For students looking to dive in: start with an introductory book with good illustrations, attend quantum events to hear from experts in person, and try cloud quantum services like IBM Quantum to experience it firsthand!
    *Note: The illustrations in Chapter 01 were generated using Gemini.
    02. Starting a DIY Quantum Computer Using the Earth's Magnetic Field!
    In April 2026, I officially started a personal project to build my own quantum computer! You might think a quantum computer requires a massive cryostat cooled to -273°C, but I am using a method called EFNMR (Earth's Field Nuclear Magnetic Resonance).
    Using the Earth Itself as a Giant Magnet
    While hospital MRIs and standard NMR machines use ultra-powerful superconducting magnets, our Earth itself is a giant magnet with a North and South pole. EFNMR uses this natural magnetic field to control nuclear spins (qubits). Because it needs no massive cooling system, you can observe and manipulate quantum mechanical phenomena right on your desk by building your own coils and circuits.
    What We Are Building (Full-Scratch)
    • Polarizing & Receiver Coil: Enamel wire hand-wound in many layers around a transparent PVC pipe holding a pure water sample.
    • Signal Processing Circuit: A custom op-amp amplifier inside an aluminum shielding enclosure to pick up nanovolt-to-microvolt signals.
    • FPGA: Dedicated digital circuitry for high-speed, precision pulse control.
    • Python: FID signal analysis, noise removal, and Fast Fourier Transform (FFT).
    • Power & Control: Lead-acid battery + MOSFET circuit to minimize power noise, controlled and monitored by an M5Stack.
    03 & 04. Simulating NMR Signals in Python: FFT and Pulse Control
    Before touching the soldering iron, let's look at how we observe and manipulate...
  • Building a Quantum Computer from scratch!
    S.I. • 10/17/2026 at 06:44 • 0 comments
    Hi everyone, I’m a KOSEN (National Institute of Technology in Japan) student, and together with my friends, I am building a DIY Quantum Computer using the Earth's Field Nuclear Magnetic Resonance (EFNMR) method. In this log, I’ll share the backstory of how I ended up building a quantum computer from scratch and give an overview of the project.
    The Origin Story: Why I Decided to Build a Quantum Computer
    My First Encounter with Quantum Mechanics and a Middle School Science Project
    I first learned about quantum mechanics when I was in my second year of middle school (8th grade). I was immediately captivated by the fact that, despite how surreal and counterintuitive quantum theory seems, it is the very foundation of how our world operates. Driven by this fascination, I conducted a science project measuring the width of slits by performing a double-slit experiment using everyday items (a CD, a holographic card sleeve, and a screen privacy filter).
    Later, I read a book about "Quantum Supremacy," which introduced me to quantum computers. The idea of fusing my love for quantum mechanics with my passion for making things (hardware DIY) completely hooked me. In my third year of middle school, I used the IBM Quantum Composer to verify quantum algorithms for another project. It was then that I decided I wanted to become a hardware engineer for quantum computers in the future.
    The Hardware Wall: Lack of Access
    While I was able to get my hands on the software side of quantum computing, the hardware—which I am far more interested in—was completely out of reach. Aside from facility tours, there was almost zero opportunity to actually touch or interact with it. Since I was a kid, my motto has always been: "If it doesn't exist, build it." So, in middle school, I looked into whether I could build a quantum computer myself. However, I found out it would cost a minimum of 300,000 JPY (around $2,000), which forced me to give up at the time.
    Discovering the EFNMR Method
    After enrolling in KOSEN, I was determined to take some kind of action regarding quantum computers. I obsessively researched DIY quantum computing again and discovered that by using the Earth's Field Nuclear Magnetic Resonance (EFNMR) method, I could start a project for about 100,000 JPY (around $700).
    Knowing this was my chance, I fully committed to building an EFNMR quantum computer. I immediately dove into the details and started by simulating the signals using Python.
    EFNMR Quantum Computer Project Details
    Operating Principle
    1. Spin Initialization (Polarization): We run a massive current through a large coil to align the proton spins (in pure water) with the magnetic field, setting the qubit to the |0⟩ state.
    2. Sequence Switching: Using a MOSFET and a relay unit, we switch the circuit between the high-current coil phase and the highly sensitive signal-reading phase.
    3. Signal Amplification: When the spins precess and try to return to their original state aligned with the Earth's magnetic field, they emit a microscopic signal (FID signal). The coil captures this, the amplifier circuit boosts it, and it is fed into the PC via a sound card.
    4. Analysis: The signal acquired in step 3 is processed using FFT and noise reduction in Python to observe the quantum state.
    System Configuration
    • Microcontroller: M5Stack
    • Sensor Coil: 250 meters of 0.5mm enamel wire, painstakingly hand-wound around a PVC pipe.
    • Proton Sample: Pure water
    • Polarization Circuit: Fully sealed Lead-Acid Battery (to prevent power supply noise), MOSFET, Fuses.
    • Amplifier Circuit: Ultra-low distortion/noise Op-Amps (AD797BRZ), Film Capacitors, Fast Recovery Diode.
    Development Logs: Past and Future
    I have been publishing my past development logs as a "Book" on Zenn (a Japanese tech blogging platform). However, I used AI to help write the text for those past logs because I actually started this project around April 2026, but only began writing articles in September 2026, so I had a lot...
View all 9 project logs
