I would first like to thank Hackaday.io for being the platform to make this contest possible, and secondly, I would like to broaden the spectrum of the definition of what computing is, because if we are going to think about retro-computing, then we need to define what computing is in the first place.
A general-purpose computer can be defined as a mechanism, that is either mechanical or electrical, that:
1. It is programmable, meaning it separates instructions from execution, separates software from hardware.
2. It can manipulate symbols according to logical rules, in other words, a digital input can be transformed by applying logical rules and produce an output.
3. It optionally performs conditional branching, meaning it can make decisions based on its own outputs, which then makes it universal-purpose.
In other words a general-purpose computer is a machine that manipulates digital inputs according to logical rules and produces outputs. A computer is essentially a machine that encodes abstract rules into removable form, then mechanically executes those rules according to symbols, then executing those symbols automatically to portray the result in an analog format to the Human senses. Must a computer be electronic to be a computer? No. from example an electric and a petrol car are both cars, the animating force does not change its essence.
Computing wasn't born in the twentieth century as popularly believed, it was born whenever Humans first realized they could separate thought from action. The separation of software from hardware really is the essence of computing in which everything else is built upon.
Computational capability is an intrinsic property of a mechanism, in other words of the actual architecture itself, and not of its intended use, for example the ENIAC in the 20th century was designed to calculate ballistic trajectories, but its architecture could calculate anything. Before it, the Z3 in 1938 did this as well, but instead of bulbs, it was electromechanical relays, yet it could also accept different programs, store different data, and execute different algorithms. Before the Z3 in 1837, Babbage steam powered analytical engine could do the same principles, in a completely mechanical way, it could manipulate symbols according to rules, store memory, and have conditional branching, meaning a mechanism that could interpret its own results and then alter its path through the program from that, in other words, using that output to control which other instructions reads next, the essential components of a universal computer,
Computation didn’t emerge from the necessity of wars as the popular story suggests, rather, the incentive to separate logic from hands first emerged from artists and craftspeople who wanted beauty to be preserved and to outlive their hands, such as a weaved cloth pattern or a musical melody. In other words the prime mover of computing was born for the service of beauty not destruction, it was only later that computers were repurposed for other things.
There is an unbroken, documented lineage from the 9th century programmable water organ, to programmable music machines, to programmable textile machines, to steam powered analytical engines, to modern computers. For example the Banu Musa water organ was built to entertain and delight, the medieval barrel organs filled European streets with melody and wonder, the automated loom wove patterns of breathtaking complexity and beauty. The computational capability was always there, each new iteration of the computer solved the problems of its predecessor, and so either made the design more portable, more efficient, faster. But the fundamental innovation was already present in the 9th century in the form of programmability, automation, and theoretical computation universality. What changed later was speed, scale, and substrate, but not the fundamental nature. For example the 1837 Babbage analytical engine insight came...
SpectrumView
brandonssmith
Squonk42
Fielding Johnston
