First proto setup
A project log for 4R4C - FPGA Radio Challenge
We have 4 Resistors, 4 Capacitors and 1 FPGA to make RADIO Receiver.
antti-lukatsAntti Lukats 04/06/2017 at 17:512 Comments
This is the first lab setup I made. The R+C are on the backside of the blue proto PCB
Yes the same setup was tested with 500Mhz signal as well..
Antti Lukats wrote 04/07/2017 at 05:17 point
Please Do not "cringe" what ever it means, The two white wires are differential output from the mixer carrying signals in range of KHz only, this is not as nice as it could be, but for prototype testing OK. Analog discovery can only deliver max 10MHz, so the orange wire was used for 3.5MHz testing. The RF wiring is not visible at all, its on the backside of the PCB and done as RF as it can be done on perforated board. The "RF Input" is 2 pins 100 mil apart.
Yann Guidon / YGDES wrote 04/06/2017 at 19:16 point
I cringe when I see how you wire "RF signals" :-D
