ASCII Keyboard Tester Tiny: test vintage keyboards
A compact board to test vintage parallel ASCII Keyboards. Use it on top of an Apple-1 or Apple ][ and/or connect their keyboards.
Evolutionary design of the legendary ASCII Keyboard Tester. It can now eavesdrop on the signals generated by a keyboard and transmitted to the vintage computer, without interfering its normal operation. Of course it still supports familiar standalone usage, so a (self-made) keyboard can be tested in isolation. All bits are annotated to ease conversion and understanding of hexadecimal and decimal number systems. Use the DIP-swich to turn off the 8th bit or activate adapter mode. The latter is to use an Apple ][ keyboard with an Apple-1 computer. All keyboard connector pins are labeled to make it easy to connect ASCII keyboards that go with other computers, like the Sol-20 of Processor Technology.
AKTtinySchematics.pdf
Adobe Portable Document Format - 357.74 kB - 10/28/2026 at 15:57
Preview
AKTtinyBoM.pdf
Adobe Portable Document Format - 95.90 kB - 10/28/2026 at 15:56
Preview
AKTtinyManual.pdf
Adobe Portable Document Format - 727.67 kB - 10/28/2026 at 15:56
Preview
