EvE v2: Two Tesla P4 GPUs on a Mini PC for $600
A mini PC with no PCIe slot, two M.2-to-OCuLink links and two used Tesla P4s: 16 GB of GPU memory for about $600.
The HP ProDesk 600 G5 Mini has no PCIe slot, but it has two M.2 slots. Each one takes an M.2-to-OCuLink adapter and a PCIe 4.0 x4 dock holding a used Tesla P4 (8 GB, 75 W). Both cards link at PCIe 3.0 x4, giving 16 GB of GPU memory for about $600 total. About 27.7 tokens/s on an 8B 4-bit model on one P4; peaks of 61 °C and 65 W per GPU under sustained inference. Full parts list, measurements, benchmarks and photos: https://github.com/SpiritualCreations42/eve-v2
Why this build
The Tesla P4 is a 75 W, passively cooled, half-height data-center card that is very cheap used. A small-form-factor PC has no PCIe slot, but the HP ProDesk 600 G5 Mini does have two M.2 slots, and OCuLink turns each one into an external PCIe x4 link. Pascal (compute capability 6.1) still runs current CUDA drivers, and the P4 has no artificial NVENC concurrent-session cap. The result is a compact, low-power box for local LLM inference, speech-to-text, transcoding and training experiments, with 16 GB of GPU memory for about $600.
How it fits together
  • Each M.2 slot in the ProDesk carries an M.2-to-OCuLink adapter, which feeds a JHH OCuLink PCIe 4.0 x4 dock. Each dock holds one Tesla P4.
  • Each dock has its own 120 W Pico PSU on its 24-pin header. Both Pico PSUs run from a single 12 V 300 W supply.
  • The ProDesk is powered separately by a 90 W universal laptop power brick.
  • A XIAO microcontroller polls nvidia-smi for GPU temperature and drives a Thermalright 12-port fan hub, which feeds nine 60 mm fans.
  • Storage: a 2 TB PNY 2.5 inch SATA SSD for boot, plus a 512 GB KingSpec NX NVMe drive in a fan-cooled ORICO 40 Gbps enclosure on the USB-C port.
Bill of materials (about $600 total, mostly used parts)
ItemQtyNotes
HP ProDesk 600 G5 Mini, barebones1Bought on eBay. Both M.2 slots used for the GPU links. Case modded to carry three fans
NVIDIA Tesla P4 8 GB2Used data-center pulls, bought on eBay
M.2 to OCuLink adapter2One per M.2 slot
JHH OCuLink PCIe 4.0 x4 dock2One per GPU. DIP switches for power-on and reset delay
120 W Pico PSU (24-pin ATX)2One per dock
12 V 300 W power supply1Feeds both Pico PSUs
90 W universal laptop power brick1Powers the ProDesk
PNY 2 TB 2.5 inch SATA SSD1Boot drive
KingSpec NX 512 GB NVMe SSD1External data drive
ORICO 40 Gbps NVMe enclosure, with fan1USB-C. Negotiated 10 Gbps on the ProDesk when checked
Thermalright 60 x 60 x 25 mm fans, black9Three per GPU, plus three on the modded ProDesk case
Copper-fin heatsink2Replaces the stock P4 heatsink
XIAO microcontroller1Polls GPU temperature and sets fan speed
Thermalright 12-port fan hub1Distributes the PWM signal to all fans
Digital fan-speed readout1Shows speed as a percentage
PCIe link (measured)
Both cards link at x4, the most an M.2 slot can offer. The docks are PCIe 4.0 capable, but the P4 is a PCIe 3.0 card, so the link runs at Gen 3. At idle the link drops to a lower speed to save power, so check it under load for the real figure.
GPUPCI addressRoot portNegotiated link
GPU 001:00.000:1b.0x4, Gen 3 under load (Gen 1 at idle)
GPU 102:00.000:1b.4x4, Gen 3 (8 GT/s)
The two cards sit behind separate PCH root ports, so each has its own link.
Power
The Tesla P4 has a 75 W power limit, confirmed with nvidia-smi, and is powered through its dock. Idle readings: GPU 0 about 6.4 W, GPU 1 about 23.7 W (light load at the time). Under sustained LLM inference on both cards, peak GPU power was 61.6 W (GPU 0) and 64.9 W (GPU 1), below the 75 W limit.
Cooling
The P4 is built for server airflow, so the stock heatsink comes off. Each card gets a copper-fin heatsink and three 60 mm fans in a cut-out shroud. Three more fans are fitted to the modded ProDesk case. All nine fans run from one Thermalright 12-port hub, and a XIAO sets the fan speed automatically from GPU temperature. The GPU driver reports fan speed as N/A because the fans are external.
Idle temperatures: GPU 0 32 C, GPU 1 38 C. Peak under sustained inference on both cards: 61 C (GPU 0) and 59 C (GPU 1).
Software
Readings were taken while the machine ran from bench-test drives, so OS-level details may differ with the final drives.
ItemValue
OSUbuntu 26.04.1 LTS, kernel 7.0.0-42
NVIDIA driver580.178.04 (proprietary, from the Ubuntu repos), CUDA 13.0
Docker29.9.2, Compose v5.6.1, NVIDIA Container Toolkit 1.20.1
Services (Docker Compose)Ollama, Open WebUI, Meshroom, nvidia_gpu_exporter, node_exporter
Benchmarks
These are LLM inference runs through Ollama, not a synthetic burn-in, so treat them...
JPEG Image - 8.34 MB - 11/04/2026 at 14:00
Preview
JPEG Image - 4.00 MB - 11/04/2026 at 14:00
Preview
JPEG Image - 4.17 MB - 11/04/2026 at 14:00
Preview
JPEG Image - 4.19 MB - 11/04/2026 at 14:00
Preview
JPEG Image - 4.08 MB - 11/04/2026 at 14:00
Preview
View all 48 files
  • Upgraded to Solar Power, WIFI AP mode, additional storage.
    SpiritualCreations42 • 11/04/2026 at 14:03 • 0 comments
    Off-grid Solar powered AI Voice assistant, Router, Gaming, Personal Cloud storage, Drone/robot control hub
    Hardware:
    HP ProDesk 600 G5 Mini PC (Ubuntu)
      - Intel I9-9900K CPU
         • Cores / Threads: 8 Cores / 16 Threads
         • Base Clock Frequency: 3.60 GHz
         • Max Turbo Frequency: Up to 5.00 GHz
         • Intel Smart Cache: 16 MB
      - PNY 64GB (2 x 32GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600)
      - PNY 2TB internal 2.5" SSD
      -  1x External 500GB 2.5" SSD SSK Enclosure
      -  2x External 500GB NVME SSK Enclosure
      -  Internal Wifi5 dual band (backup)
      -  BrosTrend USB WiFi 6 Adapter AX1800 Long Range WiFi USB Adapter
      -  Triple Thermalright TL-B6B 60mm 12V 3200RPM, Low Noise 20.17dba(Black)
      - Thermalright ARGB and Fan HUB X12 IR Black Hub Controller
      - Airhub USB conference AI Mic
      - USB Speaker
      - Dual M.2 to Oculink w/redriver adapters, 30mm shielded Oculink cables
      - Dual PCIE 4.0X4 eGPU docks, 24pin DC ATX PSU 12V DC Input DC 12V 150 watt Pico PSU ATX High Mini-ITX Power Supply
      - Dual Nvidia Tesla P4's, with Triple Thermalright TL-B6B 60mm 12v Fans
    Raspberry Pi Zero 2 W
      - Mini-USB mic
      - Adafruit mini mono speaker module
      - 128gb PNY USB drive
      - Waveshare USB HUB/ POE HAT
      - 40mm 5v fan
      - 2" color tft screen
    NETGEAR 5-Port PoE Gigabit Ethernet Unmanaged Switch
    Spiritual Creations SCSG-X5 Portable Solar Power Generator
       -4x Insulated .50 Ammunition Canisters
         - 1x Solar Control Box, 30A solar input, 12.8v LifePo4, color lcd with pushbuttons, 6 USB Ports, 12v automotive port, 1000w inverter with 2 US plugs, Dual internal cooling fans
         - 3x Battery Extension Boxes, each 12.8v LiFePo4 60AH
         - 3x 100W foldable 18v Solar panels
View project log
