TORQNYA-S2
It's just started with a rather ordinary problem:
I had more accounts than I could possibly remember. I wanted something I could carry between computers, use without depending on an online password service, and operate directly from its own screen.
So I built a rough ESP32-S2 prototype with a small OLED. It was not particularly comfortable to hold, but it could store and display account information. Before long, I added USB keyboard output and text-based scripts.
Then I ran into a familiar maker problem:
Every time I wanted another tool—perhaps a UART logger, a sensor display, or an IR remote—I was going to have to change the firmware again.
Oh, and even TOTP authentication and experimental FIDO2 support.
That's when the project changed direction. Rather than compile every little experiment into one increasingly complicated firmware image, I added a MicroPython Playground. On compatible firmware, an ordinary application is a `.py` file on a microSD card. Copy it to `playground/`, safely eject the card, choose it from the device menu, and run it.
And just like that, using it is as simple as it gets.
The device now combines a few built-in utilities with a way to make new ones. The little mechanical wrench-cat mascot reflects that mixed personality:
Part pocket tool, part curious experiment.
It consists of the following components:
- ESP32-S2 mini board (Simply because I had a few lying around) and 128 × 64 monochrome OLED.
- Rotary encoder with push action and three physical function buttons.
- microSD/TF storage for apps and device data.
- 14-pin expansion connector exposing selected GPIO, I²C, SPI, UART-capable pins, power, and ground. External signals use 3.3 V logic.
- RTC, IR transmitter, white LED, 2.4 GHz Wi-Fi, and an internal 200 mAh Li-ion battery.
- A 3d printed shell.
- And, of course, the main board I designed myself.
Now, this little gadget can do all of the following:
- Password Manager & Auto-Typing Securely store account credentials and automatically type usernames and passwords by emulating a USB keyboard.
- TOTP Authenticator Store and view TOTP codes, with support for automatic typing.
- FIDO2 Authentication Register, authenticate, and manage FIDO2 credentials, including automatic credential handling.
- Script Automation Automatically type predefined scripts and text sequences.
- Encrypted Backup & Restore Export encrypted backups of everything—including passwords, TOTP secrets, and FIDO2 credentials—and restore them on a new device. No more worrying about losing your data! TF card contents are also managed with encryption.
- Built-in Web Interface, Fully Local Manage everything through a built-in web interface. All operations run locally, with no internet connection required.
- User-Developed MicroPython Apps Users can create their own MicroPython mini-apps. Complete development documentation and API references are open-source. Just feed them to ChatGPT, Claude, or another AI assistant, and you can quickly generate working apps with AI assistance.
- And More... Startup password protection, customizable clock widgets, and other handy features.
How an Ordinary Python App Gets onto the Device
- Give the AI the SDK API documentation and simply tell it what you want to build.
- Hit Send and let the AI do its thinking.
- Download the ZIP file generated by the AI, then follow its instructions to copy the required files to your TF card, usually into the "playground/" directory. You can do this using a card reader or the device's built-in USB SD mode.
- Safely eject the drive and wait for the device to regain access to the card.
- Open Playground, select your app, and run it!
That's it! Simple, convenient, and surprisingly powerful. What a time to be alive—thanks, AI!
And here's the best part: No firmware rebuild is needed for ordinary apps that use APIs already available in the installed firmware. Of course, adding new low-level drivers or modifying the firmware itself still requires...
Jiamu
Marek Więcek
gamadril.dev
Sam P
Andrey Ovcharov
