Flappy
Extremely robust boat drone to travel the Ocean from Portugal to Antactica and come back only with solar power.
Public Chat
Project Goal: A 28,000 km, 2-year autonomous round-trip drone mission from Portugal to Antarctica to photograph an iceberg. - Hull & Core : A 1-meter 3D-printed ABS fiberglass-reinforced hull filled with polyurethane foam, housing a 100 mm PVC pressure tube for electronics. - Solar & Supercapacitors: Powered exclusively by flexible solar panels and supercapacitors (no batteries). - Zero-Maintenance Reboot: The ESP32 microcontroller shuts down nightly and reboots automatically via an analog comparator circuit, eliminating the need for a watchdog. - Propulsion & Navigation: Driven by a carbon fiber oscillating fin, the most resistant to algae, ice and plastic waste. Sensors: Features dual GPS for polar heading, a camera, and satellite communication. Everything must be extremely robust, Inox 316L everywhere, ceramic bearing, epoxy.
SEE LOG FOR NEWS !
Hello Flappy Fans!
For now, I am working on the hull. For hydrodynamics—luckily, being a sailor, I have a pretty good idea of what I'm doing ;) I have placed the fin under the boat. Regulations limit the maximum length to 1 meter for international waters, and I didn't want to lose space at the back. This works out perfectly because the top part of the fin will house the electromagnetic actuator for the fin's movement. The deck/roof is optimized to maximize the surface and is not completely flat to improve resistance against big waves, but it's well-suited for flexible solar panels. I am waiting for my new 3D printer so I can make a 20 cm prototype and test it in my bathtub ! Here some pictures.
  • 1 × ASA 3D Printing Filament ASA Filament to resist to Water and UV for the hull
  • 1 × ESP32 Microship / M5Stack ToughC5 IoT Dev Kit (ESP32-C5) M5Stack ToughC5 IoT Dev Kit (ESP32-C5) on M5StackStore
  • 1 × Be Brave
  • 4 × Marine-grade IGLIDUR bearings / Buyed on the Igus Shop Diameter 10 mm given for 184000 hours in water with movement, large enough for the course !
  • Hull optimisation finished
    clement.deymier • a day ago • 0 comments
    Hello, I received my 3D printer and printed the different hull prototypes at 1/4 scale in draft mode. A total of four iterations were needed to achieve this result, which handles waves well and moves forward properly; the earlier versions couldn't carry enough payload (estimated between 6 and 10 kg). The keel is currently a glued piece of iron, but in the final version, I will put lead inside a cylindrical keel bulb. I will soon print the boat at full scale (98 cm) to test the propulsion; I still need to add the shaft tunnel that will actuate the fin.
  • Hull Modification - News
    clement.deymier • 7 days ago • 0 comments
    Hello, first update on my project since its creation : I spent a long time optimizing the hull on Fusion 360, but the solar panel surface area was way too small. I therefore opted for a wide-deck monocoque, which will allow me to install 40W of ETFE solar panels on the surface of the craft. The deck extension is slightly raised to prevent it from dipping into the water when the boat heels.
    Two other major updates:
    • I discovered lithium-titanate (LTO) batteries, which withstand temperatures down to -40°C, don't mind being deeply discharged for months, and won't catch fire. This changes everything, and I might choose them over supercapacitors. They are quite heavy, so I'll place them at the very bottom for added stability.
    • I'll soon be receiving my marine-grade IGLIDUR bearings to support the shaft for the fin.
View all 2 project logs
Ken Yap wrote 7 days ago • point
Wow, formidable! 👍 All the best! You might want to investigate what evidence would need to be collected to be certified for the record books so that you don't miss out.
clement.deymier wrote 6 days ago • point
Thanks a lot for your comment; that’s not my goal, though I might consider it if the drone works well. I’ll create a webpage to track it—that would already be super cool!
