This is a preview. You can’t buy the board yet, because the prototype needs another revision. The full announcement is on my site.
What stays from the original speaker
The board is laid out to reuse what is already in the enclosure, so the swap needs no rewiring:
  • Battery: same connector and polarity. The board charges the cell and reports its state to Home Assistant.
  • Speaker driver: same connector, driven by the onboard MAX98357.
  • LED: sits in the original position, so it lines up with the enclosure’s light pipe.
  • Buttons: both stay. One still powers the speaker on and off, the other is yours to define.
  • USB-C port: charging and power, as before.
The original KALLSUP board above the Solo C1 board
The original board (top) and Solo C1 (bottom), with the speaker and battery connectors in matching places.
What you gain
  • Voice assistant with on-device wake word detection, through the Home Assistant voice pipeline
  • Announcements, so your automations can speak through the speaker
  • Multi-room music via Music Assistant, in sync with other Esparagus devices
  • A scriptable button, exposed to Home Assistant as an event entity
Solo C1 mounted at the top of the open KALLSUP enclosure
What I got wrong
The board is too long. I mixed up the board length when I laid it out, and it needs to be 5 mm shorter. There will be a new revision before it goes on sale.
The battery reading doesn’t work yet. On the prototype, the battery voltage divider goes to GPIO42, which has no ADC on the ESP32-S3, so the voltage and level readings mean nothing until it moves to an ADC pin. The new revision will fix that too.
What I haven’t tested yet
I’m not sure how the microphone will perform in the closed enclosure. I placed it with the listening hole facing upwards, but I can’t test it in this enclosure yet. It’s entirely possible that it will need a small hole to work properly.
What happens next
  • I’ll make the new revision with the shorter board and the battery fix. I don’t have a price or a date to share yet.
  • The ESPHome configs are already on GitHub, and the README has the pinout and the full button and battery details.
  • The schematic and PCB files will be published once the revision is released.
Esparagus Solo C1 is an independent project, not affiliated with or endorsed by IKEA.
