I recorded several waveforms. Each for pushed button. Using them I generated experiments with RFM22B to reproduce this signals. My LLM was quite helpful but it wasn't prepared to work with something which is not well documented.
After a struggle I generated experiment which gave me expected fog machine action. Large model had problems with properly pins setup, it tried to use already used pins etc. Nothing I couldn't handle.
Lets now talk about setup. this device was designed to work battery powered. One night a year. I used single 18650 LiON and battery charger with dc-dc converter for stable 5V.
After defining hardware and ways how it should work I vibe coded esp32 app to scary visitors.
pawel.j.dobrowolski
Tom
SHAOS
Rob Smith
