ENIAC and the FlipFlops
A project log for Hot logic
Ridicule doesn't kill but HV does. I hope to avoid both while using some 1Ж29Б-В and 6Н21Б
yann-guidon-ygdesYann Guidon / YGDES • 04/17/2017 at 08:54•0 Comments
Hahaha it sounds like a Rockabilly rock band :-D
More seriously I'm gathering my thoughts after (re)finding the sources and (re)interpreting the data.
I looked at the paper by Burks about the design of the ENIAC and admit it's a really impressive project. Somewhere it says that the flip-flops have two versions : one version with one triode and one with two triodes. The 2T seems easy to grasp but how is it possible to use only one triode ?
It became clear when I looked at that project (thanks to Tom Anderson) that tries to recreate a single ENIAC flip-flop. A few things became apparent :
Further looking at the ENIAC schematic, I am shocked:
Seriously guys, how many power rails do you even need ?
-555V, -470V, -450V, -390V, -360V, -355V, -285V, -200V, 0V, 20V, 50V, 225V, that's 12 rails just for this circuit !
I was complaining that I had to provide 2 supply voltages (filament and anode) but this is simply insane.
OTOH this explains how they do level shifting and AND gates: they shift the tubes, not the signals. This is getting insane...
The IBM604 is more rationalised and engineered (yet still energy wasteful), with only -100V/0V/150V...
Speaking of big bad supplies, I remember I hacked one together 20 years ago out of an old guitar amp transformer, as I wanted to use it to create my own LM3886-based bass amp. This is a symmetrical high-current, pretty high voltage supply that could work with this project... Now I have to find it in my archives :-D
