More LED testing
A project log for BreatheDot: A Portable Meditation Aid
A small battery-powered meditation aid to keep you focused and refreshed wherever you go. - Available on Tindie!
ben-limBen Lim 04/06/2017 at 20:100 Comments
I did more LED testing the other day and I concluded that the current supply can only reliably sustain 1 LED of draw current. Any higher than that the microcontroller is not able to boot. I have a few new boards that are coming in a few days and I look forward to putting them together.
I also put together a programming jig because I've had a few people who are interested in obtaining one. This will allow me to program the SMD chips easier than hooking the board up to test points, although I've included them to enable me to update the code.
