First try
A project log for Homefixer ESP8266 devboard
A lightweight and simple devboard for ESP8266-12 with 2.54mm breadboard pinout and works with 1V-5.5V batteries
johan-westlundJohan Westlund 05/16/2017 at 19:152 Comments
As got all components one week ago, I started to solder 5 boards. Result: 2 out of 5 works.
First problem was the tools I had available and the size of the components. To solve it I put on a lot of solder and then removed it again just to get flux on the pads. It really helped in sucking the solder to the pads and component the next time.
I believe that there is some shorts under the QFN on the bad ones. Will look more into it later, but for now the priority is to make 2.0 with fixes and features I really miss in 1.0.
One of the boards was put into use as a wifi thermometer sending data to thingspeak every 10 minutes. It have been running for a week with only missing half a day because the ADSL modem went down. The box haven't been touched after it was closed.
Some more problems discovered:
ESP8266 only reads 0-1V on the ADC, will have to edit the current design.
PCB was .1" to big for my breadboard, have to squeeze it a bit for the next one.
The current placement of the temp. sensor makes it a sun detector. xD
mcu_nerd wrote 05/16/2017 at 22:14 point
If you don't already have one, I would get a cheap hot air station off of Ebay (just be sure to check the wiring before powering it on for the first time.) It might help you get that pesky QFN soldered.  Thanks for the progress report.
Johan Westlund wrote 05/17/2017 at 08:31 point
I will borrow a hot air station from a friend to see if I can save the boards.  I'm just happy that I got at least one board to test using one my solderpen. Heating up the side of the big GND pad until the chip was in good position and then dragsolder the small pins.
