moar research.
A project log for WIFI Game Boy Cartridge
ESP32 emulating to be a cartridge
davedarkodavedarko 05/12/2017 at 18:480 Comments
So from far away it looks alright! I checked every byte and the data is correct. But...
Look a bit closer and you see this:
It might make sense to give the ESP the control over the OE of the data pins, since it's not fast enough to react to every change on the fly, it might needs better timing.
