- ATMEL ATTiny85 Microprocessor (or compatible 8-pin part)
- Arduino Compatible (works with Arduino bootloader and Arduino IDE)
- Prototyping area with power/ground connections
- Brings out all 5 I/O lines and the reset line to grid columns
- Laid out like a breadboard with vertically connected traces.
- Power and Ground horizontal connections though all columns
- Labeled (with letter numbers) for easy documentation
- H1 - Jumper to select regulator or remove for ISP +5V
- H2 - ISP Download Header (ATTiny85-Programming)
- AP1117 5V Power Regulator with generous area under the regulator for heat dissipation
- 2.1mm Connector for AC adapter 7-9V input
- (4) 4-40 or M3 screw holes for solid mounting
- 49x49 mm board
land-boards.com
Esmacat
Simon
chris_maker_
