Initial Designs
A project log for myWiFi Information Station
A critical display that alerts you whether or not your WiFi is on. And some other less important functions as well, I guess.
scott-clandininScott Clandinin • 02/17/2018 at 04:35•0 Comments
I changed the original vision slightly by removing the option of doing an internet speed test. I decided I didn't want to deal with having to redesign and reprogram if the internet speed test API changed or went offline.
For the frosted decal I used the website BannerBuzz with the image I designed.
I designed the enclosure in Autodesk Fusion 360 to be 3D printed.
