2 HMD Concepts
A project log for Safety Glasses With B.T. Display for Multimeter
A safety glasses with a bluetooth enabled head mounted oled Display, to diplay data from your measuring device right into your view field.
alain-mauerAlain Mauer 04/14/2017 at 12:460 Comments
I'm trying 2 head mounted display concepts. One works with a Lens with an focal length of 45mm and a reflective surface. The other one is a Lens with an focal length of 15mm and a direct view.
Both are working fine with the first tests I've done.
