Mandelbrot from TTL
A project log for Gigatron TTL microcomputer
Just because! A home computer without microprocessor
marcel-van-kervinckMarcel van Kervinck 01/22/2018 at 00:337 Comments
I got a bit stuck with the work I was planning for today, so I wrote something else to regain motivation: a fractal! Rendering takes a while (8242 seconds), being fully interpreted and lacking multiplication, and even without the "right-shift" operation you badly need for this. All those must be mimicked with slow high-level code using just addition and subtraction. [Edit: it takes 1127 seconds now with native code for "right-shift"]
It should be easy to speed the whole thing up a lot just by adding a right-shift assembly function. Next time... GCL source code:
|       Mandelbrot fractal                                              |
gcl0x
  Plot the Mandelbrot set
  - 160x120 pixels and 64 colors
  - Faithful translation of mandelbrot.c pre-study
  - Use 16-bit vCPU math as 7-bit fixed point arithmetic (1.00 -> 128)
  - Implement multiplication in interpreter
  - Implement shift-right in interpreter as well
  - A bit slow (8242.655 seconds)
  XXX At the end change all to grey tones and redo
  XXX Redo at different sections
  XXX Tone for every pixel value
|                       RAM page 3                                      |
$0300:
{ Pretty accurate multiply-shift ((A*B)>>7), but it can be off by one }
[def
  push
  {Extract sign and absolute values}
  0 sign= C=
 {0}A- [if>0 A= 1 sign=]
  0 B- [if>0 B= sign 1^ sign=]
  {Multiply}
  7 shift= {Pending shift}
  $200
  [do
    bit=
    -$4000 C+ [if<0
      C C+ C=
    else
      {Shift prematurely in an attempt to avoid overflow}
      B ShiftRight! B=
      shift 1- shift=]
    {Add partial product}
    A bit- [if>=0
      A=
      C B+ C=]
    bit ShiftRight! if<>0loop]
  {Shift}
  [do
    C ShiftRight! C=
    shift 1- shift= if>0loop]
  {Apply sign to return value}
  sign [if<>0 0 C- else C]
  pop ret
] MulShift7=
{ Calculate color for (X0,Y0) }
[def
  push
  0 X= XX= Y= YY= i=
  [do
    i 1+ i= 64^ if<>0           {Break after 64 iterations}
                                {Mandelbrot function: z' := z^2 + c}
    X A= Y Y+ B= MulShift7! Y0+ Y= {Y = 2*X*Y + Y0}
    XX YY- X0+                  X= {X = X^2 - Y^2 + X0}
                                {Calculate squares}
   {X}A= B= MulShift7!          XX=
    Y A= B= MulShift7!          YY=
    -$200 XX+ YY+ if<0loop]     {Also break when X^2 + Y^2 >= 4}
  i
  pop ret
] CalcPixel=
|}\vLR>++ ret{          RAM page 4                                      |
$0400:
[def
  push
  $7ff p= {Start of video (minus 1 to compensate for 1st step)}
  -323 X0= 3 DX= 161 Width=  {Horizontal parameters}
  -180 Y0= 0 DY= 120 Height= {Vertical parameters}
  [do
    {Length of next segment, either horizontal or vertical}
    DX [if<>0 Width 1- Width= else Height 1- Height=] if>0
    [do
      len=
      {Step in the fractal plane}
      X0 DX+ X0=
      Y0 DY+ Y0=
      {Matching step in video frame}
      DX [if<0 p 1-     p=]
      DX [if>0 p 1+     p=]
      DY [if<0 -$100 p+ p=]
      DY [if>0  $100 p+ p=]
      63 p. {White while busy here}
      {First check if we are inside one of the main bulbs for
       a quick bailout (Wikipedia)
       (x+1)^ + y^2 < 1/16}
      Y0 A= B= MulShift7! YY=
      X0 128+ A= B= MulShift7! YY+ 8- [if<0 0
      else
      {q*(q + x - 1/4) < 1/4*y^2, where q = (x - 1/4)^2 + y^2}
      X0 32- A= B= MulShift7! YY+ {q}
      A= X0+ 32- B= MulShift7! tmp=
      tmp+ tmp= tmp+ tmp= {*4} YY- [if<0 0
      else
      {Otherwise run the escape algorithm}
      CalcPixel!
      p. {Plot pixel}
      len 1- if>0loop]
    DY tmp= DX DY= 0 tmp- DX= {Turn right}
    loop]
  pop ret
] CalcSet=
|}\vLR>++ ret{          RAM page 5                                      |
$0500:
{ Stupid shift-right function }
{ XXX Better make a SYS extension for this }
[def
  a= 0 b=
  $8000 a+ [if>=0 a= $4000 b+ b=]
  $c000 a+ [if>=0 a= $2000 b+ b=]
  $e000 a+ [if>=0 a= $1000 b+ b=]
  $f000 a+ [if>=0 a= $0800 b+ b=]
  $f800 a+ [if>=0 a= $0400 b+ b=]
  $fc00 a+ [if>=0 a= $0200 b+ b=]
  $fe00 a+ [if>=0 a= $0100 b+ b=]
  $ff00 a+ [if>=0 a= $0080 b+ b=]
  $ff80 a+ [if>=0 a= $0040 b+ b=]
  $ffc0 a+ [if>=0 a= $0020 b+ b=]
  $ffe0 a+ [if>=0 a= $0010 b+ b=]
  $fff0 a+ [if>=0 a= $0008 b+ b=]
  $fff8 a+ [if>=0 a= $0004 b+ b=]
  $fffc a+ [if>=0 a= $0002 b+ b=]
      a 2& [if<>0          b<++ ]
  b ret
] ShiftRight=
|}\vLR>++ ret{          RAM page 6                                      |
$0600:
{ Main }
[do
  CalcSet!
  60 \soundTimer. {For debugging}
  loop]
|       End                                                             |
Morning.Star wrote 02/01/2018 at 07:53 point
% I'm Mandy, fly me... %
Great implementation, love the low level maths. :-D
Dylan Brophy wrote 01/31/2018 at 07:08 point
Nice work :D
Ted Yapo wrote 01/31/2018 at 04:10 point
Very nice!  I used to write these when I got bored at work - they're always fun.  Did one in SQL once - I had a big table full of pixels :-)
Marcel van Kervinck wrote 02/01/2018 at 16:38 point
You are not alone. There is a Mandelbrot implementation in Brainf*ck. And there is a BF to COBOL compiler... https://www.vanheusden.com/misc/blog/2016-05-19_brainfuck_cobol_compiler.php
SHAOS wrote 01/31/2018 at 03:51 point
this is cool :)
Matt Stock wrote 01/31/2018 at 00:03 point
Pretty cool!  I did something similar for my FPGA CPU design, experimenting with opcodes for multiply vs software implementations.  It's a great visual project to encourage you to do more tinkering.
Marcel van Kervinck wrote 01/31/2018 at 00:40 point
Thanks! In fact this was low hanging fruit. Indeed, one more speedup should be possible by migrating the fixed point multiplication logic into assembly. The challenge is to break it up into parts that can run within one scan line, but of course multiplication lends itself very well for that. I will keep that on "todo" for a later stage though. Current subproject is to add the ability to download code into RAM over the input interface through and Arduino.
