Technology used:
  • WordPress for this content site
  • Likely will use the Node full stack: Angular 4 Meteor MongoDB Ionic base
  • Two factor enabled RealMe accounts
  • Linux based servers but portable to other platforms due to use of Node
  • Github for hosting the code
  • Looking into use of Docker
  • Need help with the block-chain and authentication parts presently
