Basic user experience outline
A project log for Mezzo - informed consent for IoT
Mezzo allows your guests to understand which listening/seeing systems are in use in your house and opt-out if desired
akaAKA 03/31/2017 at 23:100 Comments
Visitor Experience
The experience of a guest is pretty simple: upon approaching the threshold of the house, they see a touchscreen showing icons that represent different listening systems:
Here's what the swipe looks like; apologies for the lo-fi prototyping:
Disabling camera systems
Homeowner Experience
Setting up a flexible system that can disable your home electronics is a bit daunting. Part of the reason I'm making this into an open project on Hackaday is that I imagine the audience will be more comfortable with technical setups than the average consumer (though, that being said, it raises a host of issues about the responsibility of selling complex and opaque surveillance technology to a mass consumer market who are unable to probe its complexities).
I don't have much of an interaction flow designed for the homeowner-setup process yet, but basically it will consist of these steps:
System Design / Complexity
...the system's internal logic is significantly more nuanced. In the next few build logs I'll talk through my reasoning for several of these problems, such as:
