7-port NanoHub now available!
A project log for Nanohub - tiny USB 2.0 and 3.0 hubs!
Need an extra USB port but a regular hub doesn't fit? Try my Nanohub!
muxmux 10/25/2017 at 06:493 Comments
By popular (2 people :-P) request, I've made a 7-port tiny USB hub. This one uses a slightly different approach for the eyelet pattern than the previous ones. Take a look at it:
Instead of in-line eyelets, I have staggered the holes to create a 1.27mm pattern. This in turn means you can use regular old 1.27mm ribbon cable or even connectors to interface the hub. Should make it just a little bit easier to solder the slightly ridiculous amount of ports on this hub.
The hub is 19.5x17.5mm and 1.6mm thick - roughly equivalent to the 2-port USB 3.1 hub.
Josef Fröhle wrote 12/14/2022 at 07:22 point
Would also be interested in the schematics for the 7 port
l.priami wrote 10/23/2019 at 21:28 point
We try to integrate this board in our electronics. At the first test directly on a PC, the Device manager say: " USB device unknown". May be it need some specific drivers? Thanks for help.
Kyle Combes wrote 08/04/2018 at 22:09 point
Hi, I'm looking to incorporate a 7-port USB hub into a PCB for a robotics project at school. Would you be willing to share the schematic for this board? Thanks!
