PI scripting cluster
Open event-based platform for Raspberry PI cluster control
This project aims at building a software stack for easy scripting on a cluster of Raspberry PIs, using an event-based distributed approach.
In general, it will be possible to define a chain of events and commands from one board to another, so a button in one pi could light a led in another with ease.
This will be a building block for more interesting concepts, such as connecting cross network and integrating with other softwares.
In a pseudo-code:
listen({fromNode: "pi0", event: "gpio_change",:gpio 2,:value 1},function(event){
sendCommand({toNode:"pi1",command: "light_led_1"});
listen({toNode: "pi1", command: "light_led_1"},function(event){
sendCommand({toNode:"pi1",command:"change_gpio",gpio:2,value:1})
The event, commands and scripts would be available every pi of the cluster and the change will reflect on all of them.
View all 2 project logs
  • 1
    Step 1
    Download the binary from https://github.com/diogok/esc/releases:
    wget https://github.com/projesc/esc/releases/download/0.0.1/esc-arm -O esc
  • 2
    Step 2
    Create your scripting folder:
    mkdir files
  • 3
    Step 3
    Start the server:
    ./esc -iface wlan
View all 5 instructions
