Arduino UNO compatible with GVS connections
The board is a minimalist Arduino design without a USB interface so it requires an FTDI board such as the USB-to-TTL Converter board to connect up to a Host Computer.The board has GVS connectors for all of the Processor I/O pins.
David Brown
Patel Darshil
Sebastian Block
SdtElectronics
Yes, delete it Cancel
You are about to report the project "GVSDuino", please tell us the reason.
