Make Water - Collaborative Water Purification
Advancing DIY Water Purification
with Students & Citizen Scientists Around the Globe.
Water coagulation plays a major part in large scale water purification processes.
We're fascinated by the potential of electrocoagulation for its simplicity, reduced environmental impact, and economic value. We designed coagulator kits so students and citizen scientists can learn about coding, 3D printing, chemistry, teamwork and philanthropy all while helping humanity unlock the full potential of this process which we believe can empower people around the globe to solve water challenges.
Electrocoagulation is process which utilizes electrolysis to bond pollutants in water until they are large enough to easily filter out.
Goals
  • Study & develop the electrocoagulation process collaboratively using DIY Open Source methods.
  • Activate and engage students and citizen scientists to participate.
  • Evolve the coagulator kits to simplify use and add data logging & sharing capabilities.
  • Share our progress through videos on our youtube make water series.
Thank Yous!
A big thank you to Les Hall. We wouldn't be this far in our project if it wasn't for his guiding light and mentorship. He introduced me to arduinos, 3D printing, and coding. He was there since the beginning when we had this idea to make small manageable coagulator kits for others to use and test and learn from.
10bitworks.com Hackerspace
Steam Central Makerspace
CoagulatorLudusSingle.ino
Arduino Uno sketch for a single coagulator with sparkfun ludus shield.
ino - 844.00 bytes - 04/29/2017 at 21:27
Download
Coagulator Ludus-Dual.ino
Arduino Uno sketch for dual coagulators with sparkfun ludus shield.
ino - 1.22 kB - 04/25/2017 at 16:38
Download
Coagulator Arduino Case-Lid.stl
3D Print STL file for Arduino Uno & Ludus Shield Case - Lid - Credit: Steam Central Makerspace
Standard Tesselated Geometry - 303.50 kB - 04/25/2017 at 17:33
Download
Coagulator Arduino Case-Base.stl
3D Print STL file for Arduino Uno & Ludus Shield Case - Base - Credit: Steam Central Makerspace
Standard Tesselated Geometry - 1.59 MB - 04/25/2017 at 17:33
Download
Coagulator 16oz Full Lid.stl
3D Print STL file for full size screw on lid for 16 oz mason jars. Credit: Les Hall - Electrical Engineer
Standard Tesselated Geometry - 1.06 MB - 04/25/2017 at 16:38
Download
View all 6 files
View all 8 components
View all 4 project logs
  • 1
    Lets make a coagulator!
    Make sure you have all your parts ready.
    1x 3D Printed Coagulator Lid - 3D File Link
    1x Mason Jar 16oz
    2x Electrodes - Type of metal is really up to you but we tend to use one aluminum and one iron.
    1x Ludus ProtoShield
    1x Arduino Uno
    2x M/M Leads
    2x Alligator Leads
    1x Power Supply
    1x USB Cable (whichever size fits your arduino)
    Notas en Espanol.
    Si alli preguntas del la systema si hablamos espanol y nos puedes mandar mensajes.
  • 2
    Connect Ludus Board to Arduino Uno.
    Conecta el Ludus Board a tu Arduino Uno.
  • 3
    Connect Arduino to your computer with the USB cord.
    Conecta tu Arduino a la computadora usando el USB cord.
View all 14 instructions
Ryan Beltrán wrote 04/25/2017 at 16:44 point
Updated the files for the new coagulator kits using ludus boards and arduinio UNOs. Still need the 3D printed case base file.
