Improving Signal Probing
A project log for Low-Cost Non-Dissipative Active Battery Balancer
This cell balancer will transfer electrical charges from a strong cell to a weak cell. Ideal for electric vehicles.
afdhal-atiff-tanAfdhal Atiff Tan 04/07/2017 at 22:090 Comments
KC Lee gave me a link showing a technique to improve grounding on scope probes. Thank you!
I immediately try it and found that it does reduce stray coupling from the board.
Unfortunately, the noise is still persists.
I later found that it is actually the high impedance balance leads that cause significant voltage drop every time the bridge transitions.
Next plans:
*Partition analogue and digital grounds
*Provide some power decoupling for the opamp
*Stiffen the supply rails for the synchronous buck converter chip
*Add flyback diodes to catch fast bemf
*Maybe replace the balance leads with lower gauge
