BLWP, RTWP, Shifts and single bit I/O
A project log for TMS9900 compatible CPU core in VHDL
Retro challenge 2017/04 project to create a TMS9900 compatible CPU core. Again in a month... Failure could be an option...
erik-piehlErik Piehl 04/23/2017 at 20:070 Comments
Ok so more progress for today. I implemented many key (unique but a little obscure) features of the TMS9900. Still testing under simulation. I decided to postpone actual hardware synthesis until I have all the instructions somehow implemented. After these additions there are not many instructions missing anymore.
I tested all of the above in simulation. Not comprehensively, especially regarding flags. But BLWP and RTWP work - I actually changed reset processing so that reset is done by forcing a BLWP from address 0. BLWP does a ton of stuff:
When doing the above, care must be taken since to capture the old values of the registers W, PC and ST before overwriting them with the new ones.
RTWP is an easy instruction - it has no operands. But it also does plenty: it reverses BLWP by loading W, PC and ST from R13, R14 and R15.
The shift instructions SLA, SRA, SRC and SRL are also flexible in that the operand to be shifted can be chosen flexible with the full slew of addressing modes. The shift count can be given as an immediate argument. If set to zero, shift counter is actually read from workspace register zero. In that case the four LSBs of R0 are used as a shift count. And there is a catch there too - if those four LSBs of R0 are zero shift count is actually 16. I think for the shift instructions the carry and zero flags at least are set properly but not sure yet of the other flags...
The single bit CRU instructions are also unique in that they use a special addressing mode that none of the other instructions use: the 8 LSBs of the instruction word become a sign extended offset to R12 for I/O bit addressing. Not only that - the 3 MSBs of I/O address are always zero and the offset is left shifted by one... The instructions are:
