First successful run
A project log for TMS9900 compatible CPU core in VHDL
Retro challenge 2017/04 project to create a TMS9900 compatible CPU core. Again in a month... Failure could be an option...
erik-piehlErik Piehl 05/15/2017 at 21:222 Comments
After some debugging I got the TMS9900 CPU core to run on the FPGA chip. That's very cool! Even in this completely unoptimised form it runs a fair deal faster than the TMS99105 processor shield I built before. The CPU core is not yet fully functional, it lacks interrupts and DIV/MPY instructions, but I can run my demo code on it. The demo runs equivalently on the new CPU core as it did on the actual TMS99105 chip:
I also tried to run the full TI-99/4A on it (as the peripheral set is the same), but it wants to go to never-never land. That is hardly surprising, as I have tested the CPU very little. It actually is more surprising that it does run the demo code correctly. That program has about 650 lines of assembly code, and it does exercise a fair amount of instructions - and interfacing to the TI-99/4A hardware on the FPGA chip, namely the interface to my TMS9918 implementation. That part of the code loads up fonts to the video memory of the TMS9918.
Before I was able to get this far I needed to integrate the TMS9900 core in a functional way to the rest of the logic I created earlier for my TI-99/4A clone. I had a bunch of difficulties in getting the CPU to run. Eventually I added debug registers to help me figure out what was not working. The CPU core component exposes a 48-bits wide debug bus, which contains three 16-bit fields:
I also added another 64-bit debug bus to my top-level VHDL module, which connects to the SRAM memory bus (my TMS9900 core uses the external SRAM as its memory, it does not use any internal block RAM). This 64-bit debug bus contains the 16-bit CPU address bus, the 18-bit SRAM address bus (there is a memory paging subsystem, and a bus multiplexer to connect to the 32-bit wide SRAM bus), a few status flags, and the last 16-bits read from the memory bus.
The beauty with the debug buses is that they are exposed through my USB memory controller interface, allowing me to see what the contents are. Normally those values would be flying by, but when the CPU core hits an opcode it does not understand it will enter a "stuck" state, and light up a LED. That allows me to see that it got stuck, and by reading the debug buses I can see what is wrong. That is the theory at least. It did help me debug the SRAM memory interface, so that my CPU core could read and write memory reliably. But when running the normal TI-99/4A ROMS, I can only see that the CPU gets stuck in a memory location it is not even supposed to fetch instructions from... That is not surprising.
But the nice thing about working with FPGAs is that I can next equip my CPU with more debug features - it seems it would be very useful to have a trace buffer, where I could store for example the last 1024 or so instructions and their addresses. I could also force the CPU stuck the minute (eh nanosecond really) it starts to execute instructions from a memory location it is not supposed to run code from.
Xark wrote 05/16/2017 at 06:29 point
Sounds very nice!  With an FPGA it is nice to add an ICE to your design all with a few lines of "code".
Erik Piehl wrote 05/16/2017 at 10:58 point
Thanks! Exactly, there are very many debugging/tracing aids that can be simply added to the design. Since I already have the communication software on the host PC (it communicates over USB with a memory controller state machine on the FPGA) I can easily pull a lot of sophisticated data out from the system, this should be a great help finalising the CPU implementation.
