MPY and flag fixes
A project log for TMS9900 compatible CPU core in VHDL
Retro challenge 2017/04 project to create a TMS9900 compatible CPU core. Again in a month... Failure could be an option...
erik-piehlErik Piehl 05/21/2017 at 06:370 Comments
Real life has kept me busy... I did a few small tweaks to the TMS9900 core: I added support for the MPY (multiply) instruction. I also started to implement CPU status flag support more carefully, and implemented a few changes to the handling of ST0 (Logical Greater Than) flag, as well to the handling of ST1 (Arithmetic Greater Than) flag. ST0 is the MSB i.e. bit 15 of the status register, while ST1 is bit 14. For whatever reason the TMS9900 generates these flags in what seems to be an inconsistent way: for both flags the "correct" behaviour is only done with the compare instructions (C, CB, CI). With other instructions (except special handling of ABS instruction - I did not implement that yet), the flags become simpler and mostly just versions of "non-zero" flags.
The multiply instruction I implemented with Xilinx Spartan 6 hardware multiplier, so this instruction (while not optimized) has a much higher performance than on the original CPU. Reading the data sheet the multiplier can compute the multiply operation in 3 cycles - it could do it even faster in pipelined mode but that is neither necessary or useful on this CPU core.
I have three test programs that I use for testing: the original TI ROMs, my custom boot loader and a instruction test program I use for simulation. My custom boot loader has the ability to start the Defender game, if the ROM image for that cartridge has been loaded. Both of my own test programs work, but the TI ROMs still do not work. With the changes to the handling of flags, now the Defender cartridge image renders the first screen before somehow crashing. So some progress, but still no beef yet.
