The modification
A project log for Tusotek DC/DC Boost - Constant Current
How to modify the low-cost "Tusotek 200W DC/DC Boost Converter module" to be a Constant Current controlled converter (boost LED driver)
benjaminaignerbenjaminaigner 04/02/2017 at 08:050 Comments
It's very easy to modify this converter to be constant-current controlled:
You need following parts:
As you can see in the schematic image, not very much to do.
If you need further help, please write :-)
I tested this setup already with following currents and LED power:
You can adjust the current with the poti, if it has the lowest resistor, the current is also the lowest possible one. Due to the FP1539 feedback circuit, the controller regulates until there are 0.5V at the feedback pin.
If you have a 0R poti, this eqals to:
I = U / R = 0.5V / <R-shunt> = 0.5V / 0.68Ohm = 0.735A
Of course, a lower shunt value increases the minimum current, but it also decreases the power losses on the resistor:
Pshunt = I out ² * Rshunt = 1.75A² * 0.68Ohm = 2.1W -> nice, within the specs :-)
If you want to increase the efficiency, decrease the Rshunt value.
For example: If I know, that I only use about 1.5A (or 1.75A+/- a little bit adjustment), let's try different values:
I = U/R = 0.5V / 0.47Ohm = 1.06A min -> Pshunt = 1.75² * 0.47 = 1.43W (only 70% of the previous value)
next value
I = U/R = 0.5V/0.33Ohm = 1.51Amin -> Pshunt = 1.75² * 0.33 = 1.01W (even more efficient)
Ok, for my setup, I will modify my CC controller to support only 1.5A+, but it reduces the wasted heat by 1W (2% :-)).
Next time, I will write about the whole feedback circuit in detail!
