PCBs
A project log for LED Matrix Watch
Wrist watch with monochromatic 16X16 LED Matrix inspired by retro LED watches of 70s and 80s.
mileMile 06/03/2017 at 21:171 Comment
Here are the pictures of PCBs that arrived few days ago. Since these are the first PCBs that I ordered from OSH Park, I decided to inspect them in detail under microscope. Gold plating on copper is smooth, evenly distributed and nice to solder on (tried test soldering few components on one PCB). Silkscreen is smooth, "high resolution" and looks way better than on Chinese PCBs (Chinese mostly use dot matrix printers so theirs silkscreen looks "pixelated"). Only downside is that solder mask isn't perfectly aligned with pads, but that wont be a problem.
oshpark wrote 06/07/2017 at 02:18 point
In regards to "Only downside is that solder mask isn't perfectly aligned with pads, but that wont be a problem", could you please email the order number to support@oshpark.com?  Our goal is perfect boards and we appreciate when customers that let us know about any issues.  Thanks!  Drew Fustini <drew@oshpark.com>
