Power source
A project log for Raspberry Pi-based SmartZoom Imaging
Using a laser rangefinder, distance from camera is calculated and display of image is zoomed in or out dependantly
kendoken.do 09/03/2017 at 03:020 Comments
I got a LiFePo4wered Pi power source from Patrick some time ago.
This is a great little power unit. A 18650 joins up with the GPIO pins and hangs off the side of the Pi. For my application, I will need the LiFePo above a Pi Zero. A few minor alterations should put things where I need them.
