Fire it up
A project log for Arcus-3D-M2 - Ceramic Heated Bed
Low cost, large build diameter heated bed made from a floor tile.
daren-schwenkeDaren Schwenke 04/10/2017 at 19:190 Comments
Got to try the new heated bed out today and got some stats.
It took about 5 minutes to heat to 90C, starting from 25C.
Surface temp was pretty even. It was about 3 degrees cooler near the edges, and varied by about 1 degree otherwise across the surface. Where I had attached the feed wires, it was about 5 degrees cooler.
Good enough.
Fire It Up
