Adding a slider... Adding?!
A project log for Mouse Aid
With this companion your mouse will be able to perform fine and precise movement in drawing applications
danjovicdanjovic 04/02/2017 at 21:420 Comments
The first thing that came to my mind to add a slider was to use a potentiometer in series with a 1K resistor.
Then I remembered that the ground is not available at the I/O header.....
This is bad... very bad.... It leaves me with only two options.
