Hints for using the CDC USB Serial
A project log for Notes on Using SystemWorkbench with STM32 BluePill
I finally succumb to IDE madness... for awhile.
Al WilliamsAl Williams 04/11/2017 at 03:050 Comments
When you add the USB CDC serial to your project, you don't get much help about what to do next. The CDC_Transmit_FS call is pretty obvious. Give it a message and a length and it sends it. Fair enough.
Receive, though is via a callback named CDC_Receive_FS. You don't call this. The framework calls it for you.
Here's my version:
static int8_t CDC_Receive_FS (uint8_t* Buf, uint32_t *Len)
  /* USER CODE BEGIN 6 */
uint32_t len=*Len;
if (hUsbDeviceFS.dev_state != USBD_STATE_CONFIGURED)
   return USBD_FAIL;
if (((Buf == NULL) || (Len == NULL)) || (*Len <= 0))
   return USBD_FAIL;
/* Get data */
uint8_t result = USBD_OK;
    do
        result = USBD_CDC_SetRxBuffer(&hUsbDeviceFS, &Buf[0]);
    while(result != USBD_OK);
    do
       result = USBD_CDC_ReceivePacket(&hUsbDeviceFS);
// add data to FIFO
    while (len--)
       if (FIFO_INCR(RX_FIFO.head)==RX_FIFO.tail)
             return USBD_FAIL;  // overrun
       else
        RX_FIFO.data[RX_FIFO.head]=*Buf++;
       RX_FIFO.head=FIFO_INCR(RX_FIFO.head);
   return (USBD_OK);
  /* USER CODE END 6 */
This in in one of the headers:
#define  FIFO_SIZE 32  // must be 2^N
#define FIFO_INCR(x) (((x)+1)&((FIFO_SIZE)-1))
/* Structure of FIFO*/
typedef struct FIFO
uint32_t head;
uint32_t tail;
    uint8_t data[FIFO_SIZE];
} FIFO;
extern FIFO RX_FIFO;
Then you need a way to read it out, too
/* Create FIFO*/
FIFO RX_FIFO = {.head=0, .tail=0};
// returns bytes read (could be zero)
// would be easy to make it end early on a stop char (e.g., \r or \n)
uint8_t VCP_read(uint8_t* Buf, uint32_t Len)
  uint32_t count=0;
/* Check inputs */
  if ((Buf == NULL) || (Len == 0))
  return 0;
while (Len--)
if (RX_FIFO.head==RX_FIFO.tail) return count;
count++;
*Buf++=RX_FIFO.data[RX_FIFO.tail];
RX_FIFO.tail=FIFO_INCR(RX_FIFO.tail);
return count;
