Added block commands
A project log for Ugly USB
After the Good and the Bad here you are the Ugly USB!
danjovicdanjovic 04/30/2017 at 20:120 Comments
Now it is possible to expand the DuclyScript by repeating blocks of commands.
For example the following script will open 10 notepads an type in Hello World.
DELAY 3000
BEGIN
GUI r
DELAY 500
STRING notepad
DELAY 500
ENTER
DELAY 750
STRING Hello World!!!
ENTER
AGAIN 10
The start of a block is marked by BEGIN command and the end of the block is marked by the AGAIN command which receives an integer parameter.
Sources for the Test Sketch as well as for the Compiler were updated on Github as well.
