Schemas for everyone~!
A project log for IoTNode
Building an OpenSource IoT Platform for the Average Maker. Using Open Connectivity Foudnation's OIC Spec and example Apps
roman-vRoman V 04/26/2017 at 10:280 Comments
The next project log is still on the way. It's delayed as I'm trying to figure out a problem with data models.
This project is a mix of software and hardware development. The software part is rather tricky so I'm putting efforts into making the code base modular (or more accurately, making libraries).
The biggest hurdle I'm facing right now is dealing with JSON Schema. Since each device can have multiple resources, where each resource provides data that is described with one or more JSON schemas. OIC Spec v1.1.0 contains quite an extensive list of schemas for various resources. (doors, heart rate monitors, air conditioners, etc). So I'm deciding on how to deal with them, since vendors may specify their own schemas, it's just becoming a bit of a mess.
The plan for now will be generating code for the known schemas in OIC spec v1.1.0, whill be some work honestly. but hopefully soon i'll have a nice generic library that is not too complicated to use, which will be extended later on with dynmic things
