So i finally got round to putting the click domes onto the board. The are a little wider than the tactile buttons i was using before, but then they are slightly shorter. I have been playing about with the layout on the board, and thought i might add in some GPIO pins each side of the screen just to make use of the extra space.
here is the latest progress, i did try cutting out the screen sides but i dont think i like it. as always DO NOT ORDER!! this is just for info
