ITS ALIVE!!!!!!!!!1
A project log for Pi0CKET - Clicker
To get the true Pi zero experience in your pocket, we are gonna need some buttons!!
mooseprmoosepr 10/01/2017 at 19:245 Comments
I was a little apprehensive about hand soldering the QFN24 chip for the keyboard, looking at it, the thing was crazy small! I forget how small things are after spending many hours with stuff zoomed a few hundred percent on the computer screen
(dont look too hard, my keyboard needs cleaning)
so i took the plunge
tinned the pads with a small amount of solder, applied a later of flux, clamped the chip with some tweezers and a clothes peg (nothing like having the right tools) and gave it some love with the iron
finding the limits of my phone camera, and it looks better in person.
much soldering later and we have filled the pads
I burnt some code onto the attiny85, grabbed the nearest sd card with ili9341 running, added a battery and pressed the button
looking good!!
There are of course issues, my idea of using a clip on programmer is fine for the attiny85, but when the pi covers the chip, you can no longer program it!! need to add a ICSP header. Im also struggling slightly to get my attiny to behave as i want. Getting it to respond over i2c kills my sleep code, think i have some conflicting interrupts...
to be continued......
oshpark wrote 10/02/2017 at 04:00 point
exciting!
zakqwy wrote 10/01/2017 at 21:56 point
nice job!! also agree re hot air gun!
moosepr wrote 10/02/2017 at 05:22 point
Yeah, planning on making a little reflow oven for the future
deʃhipu wrote 10/01/2017 at 21:12 point
This is where you get yourself a cheap hot air gun — those chips simply jump into their place.
You probably want to make those LEDs a bit less bright.
moosepr wrote 10/01/2017 at 21:26 point
yeah its a little bright, tis using the adafruit neopixel library atm, bridgtness is set to 25 out of a possible 255!! will probably end up covering it a bit
