The 8×8 Monochrome Matrix Finished
A project log for D1 Mini Matrix Deluxe Shields
Shields for the D1 Mini ESP8266 board using the ISSI chips
dehipudeʃhipu 04/19/2017 at 19:421 Comment
Well, almost. There is going to be one more version of the PCB, because of course I swapped one of the rows with one of the columns of the matrix.
You can also see that one of the rows has a cold joint in there, but that was easily fixed.
I also wrote a MicroPython library for this matrix, which is available at https://bitbucket.org/thesheep/micropython-is31fl3728/src
I will still need to update it to reorder the rows and columns to fit the reality -- but I will do that once I get a final working PCB.
oshpark wrote 04/20/2017 at 06:23 point
great to see you're making progress.  MicroPython library is a nice touch.
