*Update 2 nov 2017*
Unfortunately I could get the ili 9327 to work on the stm32. So I opted for a dp5020 module instead to get the project finished and working. More on that soon.
*Update*
Getting the ili9327 TFT Touchscreen to work with stm32 is quite more challenging as I expected as there are no easy to use libraries available.
*Update*
The toner transfer method seems to work ok for low resolution prints. Also the method using spray paint seems to work much better with my toner. I will try to use this for the build.
Right now I'm printing the cover for the fan on the bottom.
*Update*
The blank PCB's have arrived and I need to try different methods for making a custom pcb.
Possibilities:
-toner transfer method
-plotting lines on pcb with 3D printer
-milling pcb with 3D printer
-uv transfer method
Matthias
sako0938
deluxe87
