Using a Raspberry Pi Zero to power a kiosk that shows calendar and weather. Updates every 30 minutes. I added a face identification feature that takes a picture every second, uses OpenCV to identify faces, then saves that photo locally if there's a face in it. I'm in the process of adding a logging feature to note the time of the observance. Also plan to add facial recognition soon so it can tell me whose face it sees.
This is looking very impressive idea you can click on the house removals preston website to solve this issue.
