Problems and soultions.
A project log for Robot 3D printer auto eject sys & web print queue
A 3d printer system that can be operated by multiple people that just spits out parts placed in the web based print queue
mmiscoolmmiscool 07/23/2017 at 06:340 Comments
so I was having some trouble with EMI. When the relays or switches were opening there would be a pulse from the coil in the motor that would interrupt the serial communications with the computer. This was the bane of my existence for a while.
I rigged up a couple of limit switches to control the linear actuator that the print head would hit using a bit of gcode.  and it was working great. That was untill some one uploaded a file that was way to big for the printer and the print head broke the limit switches. I have been working to make it so that there is a check for the print size to prevent future problems.
Might also get an h bridge motor controller for the linear actuator.
