Made some changes tonight. Fixed some issues. We have a working machine.
A project log for Robot 3D printer auto eject sys & web print queue
A 3d printer system that can be operated by multiple people that just spits out parts placed in the web based print queue
mmiscoolmmiscool 07/11/2017 at 02:500 Comments
So there were several problems each compounding the other.
I had removed some code from the gcode sender to reset the serial connection between prints. This has been added back in.
The extruder had a loose wire for the heater so that caused some head ache. That has been corrected now.
As of tonight there is a functional printer that can work continuously. I will be working on getting the documentation updated with dimensions to build the printer.
Hopefully some one will be brave enough at that point to replicate the machine. Then the fun begins.
